It locks it in for the specified value and the (+ value 180).
The OP asked:
Now how do I get the 45 angle to slant down and right?
The
  • Replies 31
  • GE13579
    8
  • ReMark
    6
  • GMPAO
    5
  • davebate
    5
The OP asked:
The
I stand corrected. Sorry.
GMPAO: Hope you've been taking notes. One task with many ways of accomplishing it. The choice is yours.
ucs z 13 might help
:shock: Not sure how rotating the ucs 13 will help? To go down that route surely would be long winded, but will require the following:
Command: ucs
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
: z
Specify rotation angle about Z axis : -45
Command: plan
Enter an option [Current ucs/Ucs/World] : C
Regenerating model.
Command: l
LINE Specify first point:
Specify next point or [undo]: 13
Command: ucs
Current ucs name: *NO NAME*
: w
Command: plan
Regenerating model.
Command: UCS
: Z
Specify rotation angle about Z axis : 13
How difficult is tthat takes less than a second
Command: UCS
: Z
Not difficult I know, but you're not answering the OP's question and are giving misleading information- you're rotating 13° when the OP wants a line 13 long at an angle of -45°.
You really change the UCS for every line you draw? :shock:
I know th length of the line that's at an angle is 13' but I don't know which coordinates will get me there. sorry i was trying to help this is in the thread and a statement that was made
You do know that 13' is 13 foot, not 13 degrees?
Is it possible to enter a line as an angle without knowing the @ #,# and only knowing the line distance?
Ok, just so I better understand, if I have a 13' long line and I want it at an angle I will type 0,0 then ENTER and type 13,13 ENTER?
sorry mate read the thread re references to degrees very confusing to a 25 year amiter like my self have you now gon back to the dark ages feet and inches
No worries Dave the line you referenced was a little misunderstanding... but be careful about coining feet and inches as being from the dark ages... our colleagues across the pond might not take lightly to that (imperial measurement is standard in the US and also in some disciplines in the UK I think?). :)
ok i was trying to help having a bad day but much apprecated for you response
hope the day gets better wont happen again
No worries I always get things wrong here! :oops::)
