mojo8997 Posted October 21, 2009 Posted October 21, 2009 im a lisp noob to start, what i have is a lisp where i have to select lines 1 at a time, and it sounds like i can use ssget to make the selection a lot easier. My friend helped me put this together and was unsure about how to use ssget. Any help would be much appreciated! Thanks (defun c:DVD (/ ssete CNT) (command "_.undo" "_begin") ;;- Pick an existing line (setq CNT T);Simple on/off toggle for while loop (while CNT (if (setq PICKLINE (entsel "\nSelect Lines To Divide")) (COND ((not ssete);List does not already exist, create new lists. (setq ssete (cons (car PICKLINE) ssete)) );end cond ((and ssete (not (member (car PICKLINE) ssete)));Lists exists, check if object already exists in the entity list (setq ssete (cons (car PICKLINE) ssete));add entity name to entity list );end cond (t (princ "\nObject previously selected."));If object already exists in the list, );end COND~ ;|else|;(if (= (strcase (getstring "Selection Complete?. Exit? (Y/N) <N>:")) "Y") ;|then|;(setq CNT nil);No object selected, set CNT=nil to drop out of while );end if );if );while (setq ssete (reverse ssete)) (setq SSLEN (length ssete));how many in the list? (setq CNT 0);set initial counter value (while (/= (setq PICKEDLINE (nth CNT ssete)) nil) (command "Divide" PICKEDLINE "10") (command "Erase" PICKEDLINE "") (setq CNT (1+ CNT)) );end while (command "_.undo" "_end") (princ) );end defun 3P Quote
ronjonp Posted October 21, 2009 Posted October 21, 2009 Try this: (defun c:dvd (/ e n ss) (setq n -1) (if (setq ss (ssget ":L" '((0 . "LINE")))) (while (setq e (ssname ss (setq n (1+ n)))) (command "_Divide" e "10") (entdel e) ) ) (princ) ) Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 Well, I already coded it, so I'll post it anyway. (defun c:DVD (/ SS Index Ent) (cond ((setq SS (ssget "_:L" '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE")))) (command "_.undo" "_begin") (setq Index -1) (while (setq Ent (ssname SS (setq Index (1+ Index)))) (command "_.divide" Ent 10) (entdel Ent) ) ;_ while (command "_.undo" "_end") ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 LoL We wrote them virtually the same way. Quote
ronjonp Posted October 21, 2009 Posted October 21, 2009 LoLWe wrote them virtually the same way. Good you put the undo points in there Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 Good you put the undo points in there I actually stole this method from you a while back: (while (setq Ent (ssname SS (setq Index (1+ Index)))) Quote
ronjonp Posted October 21, 2009 Posted October 21, 2009 I actually stole this method from you a while back: (while (setq Ent (ssname SS (setq Index (1+ Index)))) Thief!!!! j/k...I've stolen\borrowed my fair share too. Quote
mojo8997 Posted October 21, 2009 Author Posted October 21, 2009 wow that sure shortens the code up a lot lol, thanks a lot guys !! Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 Thief!!!! j/k...I've stolen\borrowed my fair share too. What better way to advance yourself. LoL Quote
alanjt Posted October 21, 2009 Posted October 21, 2009 wow that sure shortens the code up a lot lol, thanks a lot guys !! A lot less legwork too. Give this site a look: http://www.afralisp.net/lispa/lisp19.htm Quote
