lulumara Posted October 21, 2009 Posted October 21, 2009 Need to know if Align command is in AutoCad 2009 LT because I was using it the Cad 2009 LT doesn't recognized it. Or I missing something??? I saw Align Dimensions but that one is different ? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 There is an ALIGN command in LT but it is different from that in the full version. Quote
lulumara Posted October 21, 2009 Author Posted October 21, 2009 Hi Remark what's the command ?? I was looking at the All command but can't find any?? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 An ALIGN command that can be used in LT available here. See response by Gilbert L. "Chip" Harper to a question similar to yours. I believe it is a macro. http://discussion.autodesk.com/forums/message.jspa?messageID=5227231 Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Or try taking a look (demo available) at LTExpress 2: http://www.ltexpress.com/ Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Hi Remark what's the command ?? I was looking at the All command but can't find any?? Don't know what I was thinking when I wrote what I did. The ALIGN command is available in AutoCAD LT 2010. Quote
lulumara Posted October 21, 2009 Author Posted October 21, 2009 Hi Remark, I'm not familiar with Macro any pointers to make it work the Macro , Can show it to me step by step . Quote
lulumara Posted October 21, 2009 Author Posted October 21, 2009 I did a customization of the align command in the Interface , I can see it in the interface but can't grab it to place it in the toolbar. Am I missing something, I did checked it my old notes and saw the procedure to use Macro but can't work it out?? i did tried align command but didn't work unknown command??? Opps didn't notice that you said that Align command is only available in 2010 Lt only but does the Macro works on 2009 LT?? Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Sorry but I cannot provide you with step-by-step instructions at the moment. Creating a button for a macro is something that has been covered in Michael's Corner. Basically, it involves editting the CUI. I created a new button called AlignLT and placed it on a custom toolbar I created a while back called PowerTools. The macro that I gave you the link to previously will definitely work. I know as I tested it. Quote
lulumara Posted October 21, 2009 Author Posted October 21, 2009 I did copy and paste the Macro for Align command to the interface but can't use to work??? Quote
lulumara Posted October 22, 2009 Author Posted October 22, 2009 Any idea, how I can use the align command that I made in Macro??? Quote
ReMark Posted October 22, 2009 Posted October 22, 2009 Yes. Aligning a 2x2 square with a 3x2 rectanle would be a simple example. Think of it as just what it is a combination of move and rotate using reference points. Actually the real ALIGN command in the full version of AutoCAD gets the most use by me in 3D. How about aligning a sink with a wall that is drawn at an angle? Quote
lulumara Posted October 22, 2009 Author Posted October 22, 2009 Hi remark , I know how to use it but I cannot bring the Align toolbar that i made in Macro to the AutoCad workspace. Quote
ReMark Posted October 22, 2009 Posted October 22, 2009 After you went through all the trouble to create a custom macro and button you did click on the APPLY button and then on OK before leaving the CUI editor right? Quote
lulumara Posted October 22, 2009 Author Posted October 22, 2009 Yap I did apply and ok before leaving the CUI editor but can't make it to work? I did look at the file it said: c:\Document and Setting\Name\Application Data\Autodesk\AutoCad LT2009\R14\enu\Support\Icons\ALIGN.BMP Does this files work? Quote
ReMark Posted October 23, 2009 Posted October 23, 2009 I was able to get my macro designed and functional on the first try and making macro buttons is not something that I do on a frequent basis. All I can say is you must have done something wrong and perhaps to try again. If I think of another possibility I will return and post further comments. Quote
lulumara Posted October 23, 2009 Author Posted October 23, 2009 I did redo the Macro of Align command but same process it doesn't work??? I can't grab the Align button that I made but no avail? Quote
