LLines aren't showing up correctly in my drawing. Linetype scales are wrong. I've tried 100000000 to 0.0000001 etc and it doesn't change at all (stays a striaght lien when it shouldn't be). How do I change the global scale or reset it?
Thanks, that is what I was looking for. Although it didn't fix the problem. Redrawing the lines worked (i.e. new lines) and displayed correctly, however the existing/old lines would not display even though their properties appeared to be identical to those of the newley drawn lines which worked fine.
