I was wondering if anyone knew or has some code that can do this, I am trying to change the color of TEXT below a certain size on my drawing, and just cant seem to get it right.
You can use QSELECT to select textobjects of a certain textheight, I assume that in the FILTER command you can set a AND-filter to get a bunch of text objects selected. After you have them selected, pull up Properites and change the color.
well yes i know, but im trying to use code to do this automated. is a example of what im starting off with:
Function CHANGETEXTBACKTOWHITE(strErrors)
'* Variable Declarations
Dim S99 As AcadSelectionSet
Dim Ftyp(3) As Integer
Dim errCount As Long
Dim Fval(3) As Variant
'* Program Begins
'* Changes Text Back to White
Ftyp(0) = -4: Fval(0) = "
'Ftyp(1) = -4: Fval(1) = "
Ftyp(1) = 67: Fval(1) = "0" 'model space
Ftyp(2) = 0: Fval(2) = "TEXT"
'Ftyp(3) = 0: Fval(3) = "MTEXT"
'Ftyp(3) = 62: Fval(3) = 6
Ftyp(3) = -4: Fval(3) = "AND>"
Set S99 = ThisDrawing.SelectionSets.Add("S99")
S99.Select acSelectionSetAll, , , Ftyp, Fval
If S99.Count > 0 And TextHeight
'And TextHeight
'And ActiveTextStyle = "Standard" Or ActiveTextStyle = "Logo"
'And TextHeight
For errCount = 0 To S99.Count - 1
S99(errCount).color = acWhite
Next errCount
End If
ThisDrawing.SelectionSets("S99").Delete
End Function
