Freerefill Posted October 23, 2009 Posted October 23, 2009 So I was trying to code a base converter (you know, like base 10 to binary, that sort of deal) in LISP, and for some reason, what I was getting back wasn't working even though my math was spot on. I struggled with it for quite literally hours before stumbling upon the problem. Now I don't know if this will work the same on every version, but try this out. Paste this in the command line (/ 51.0 10.0) Returns 5.1, right? Well yeah, that's what you'd think it would do. Now try this: (* 10 (rem (/ 51.0 10.0) 1)) For anyone not following me, I'm taking the remainder and multiplying it by 10. Returns 1.0, right? Well now, lets test that. (fix (* 10 (rem (/ 51.0 10.0) 1))) "fix" removes the remainder from a floating point number and returns the integer portion. So waitatic, why is this returning 0? Isn't the integer portion of 1.0 1? Go ahead and try it: (fix 1.0) So it seems yes, it is. So then why is it returning an incorrect number? There's only one way to peer deeper into a number, and that's by turning it into a string, and forcing it to display the extra digits. (rtos (* 10 (rem (/ 51.0 10.0) 1)) 2 16) "rtos" turns a real number into a string. As you can see, 0.9999999999999964 is not equal to 1.0. Close, but no cigar. Is this a problem with AutoCADs division operator? I know computers only work a certain way, but this has caused me hours of grief. I could understand if the numbers were very large, how significant digits would definitely play a part, but I think 51 and 10 are relatively small, and should not be causing an error like this. Quote
CarlB Posted October 23, 2009 Posted October 23, 2009 I see there is some error that crops up in the very small decimals; happens with computers/computing. What are you trying to determine? If its' a decimal portion of a real, there are better ways than with 'rem', which is more suited to division of integers. Quote
