bchou Posted October 23, 2009 Posted October 23, 2009 hi all, recently we have changed our pdf'ing program, but now i find that our old projects with our set page setups not working properly, instead of changing the name of our new pdf program; is there a program or better way to update page setups into each drawing other than the import or open each drawing and modify the pdf program? something similar to reference manager(AdRefMan.exe) - how you could mass modify a selected amount of drawings. any pro suggestions? Quote
tzframpton Posted October 27, 2009 Posted October 27, 2009 hi all, recently we have changed our pdf'ing program, but now i find that our old projects with our set page setups not working properly, instead of changing the name of our new pdf program; is there a program or better way to update page setups into each drawing other than the import or open each drawing and modify the pdf program? something similar to reference manager(AdRefMan.exe) - how you could mass modify a selected amount of drawings. any pro suggestions? Were they set up using a *.PC3 file? If so, then all you have to do is remake the plot configuration file using the new PDF print driver, then rename it to the old one. If you simply used the PDF print driver itself and saved the Page Layout, then you're kinda screwed unless you write a program. I wonder if you could even rename the default printer name through Control Panel > Printers?? You might even try that, now that I think about it. Quote
