Scoobydoo Posted October 27, 2009 Posted October 27, 2009 I am creating a drawing (using our 8-1/2 x 11 template) from an assembly and would like to know how I can show/print the assembly in color instead of black. Any suggestions would be helpful. Thanks! Quote
Scoobydoo Posted October 27, 2009 Author Posted October 27, 2009 Nevermind, I got it figured out! Quote
shift1313 Posted October 28, 2009 Posted October 28, 2009 Keep in mind when you print a drawing in shade mode, the appearances are the most current in your model. For instance if you change the transparency of a box to show components on the inside, this will be shown in the drawing. You can also create other model states such as exploded line views, flat patterns of sheet metal and so on and use these all in the drawing. Quote
