Simple LISP To Explode All MText?
I tried this, but it does not seem to work:
(defun c:ExplodeMtext ()
(command "._explode" (ssget "_X" '((0 . "MTEXT"))) "" )
Anyone have a simple LISP that will explode all mtext in a drawing?
Link to post
I got this to work... But it only explodes one occurrence of mtext...
(defun c:EXMT ()
(command "._explode" (ssget "X" (list (cons 0 "MTEXT"))) )
I want to explode all mtext in one sweep.
Link to post
Try something like this, untested:
(defun c:Explode_Mtext (/ i ss ent)
 (if (setq i -1 ss (ssget "_X" '((0 . "MTEXT"))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (command "_.explode" ent)))
 (princ))
Link to post
Hey Lee;
That works great... I am getting an Unknown command "Explode_Mtext" error at the end, but it is working. I guess there is one too many () or "" somewhere.
Link to post
So this is what I changed to fix the error at the end:
(defun c:EXMT (/ i ss ent)
     (command "_.explode" ent )))
I changed the name only because I have a button that calls that name out and I am too lazy to change it... lol...
Thanks for the help Lee!
Link to post
The first lisp you posted would have worked, if you first set "QAFLAGS" to 1.
Or you can set it in the outine, then set back to original.
QAFLAGS affects exploding a set in lisp, among other undocumented effects.
Link to post
I have never used QAFLAGS... Could you show me the LISP the way you are talking about with the QAFLAGS?
Link to post
Sure...
(setq UsrQA (getvar "QAFLAGS"))
(setvar "QAFLAGS" 1)
(setvar "QAFLAGS" UsrQA)
Link to post
  • 11 years later...
