Insert Multiple DWGs into one.
I am using ACAD Map 3D 2010. I am having trouble finding a way to insert multiple drawings into a single drawing. I used to use the XREF command but now it only allows me to choose a single file to xref. Is there a way to xref Multiple files at the same time?
I thought the xref multiple problem was fixed with SP1. Unless Map 3D was not patched.
