saadicarnot Posted November 2, 2009 Posted November 2, 2009 I converted a drawing in PDF format to DXF by using Aide PDF to DXF converter. The file was converted but as I open the output in AutoCAD I get a following error: DXF read error on line 2275. Invalid or incomplete DXF input -- drawing discarded. Press ENTER to continue: I have used Aide output in Autocad before and there were no errors for those files. It gives the mentioned error for only few drawings which I recently wanted to use in my Layout. Any help would be great. Thanks. Best regards, Saad Quote
