Hi all,
I seem to have trouble dimensioning multi lines in paperspace.
They seem to be dimensioned with the vport scale.
Lines etc. dimension correctly. Also when I explode the multi lines, they dimension correctly.
Is there anything I can do to correct this?
Thanks
First heard of this problem a couple of months ago. Searched the AutoDesk website for a cause/cure but came up empty. Perhaps your post will result in another forum member being able to shed some light on this perplexing problem as it how once again raised my curiousity as well.
