NZ Steve Posted November 3, 2009 Share Posted November 3, 2009 Any of you guys seen this? I am trying to use the GATTE command that I have been using for YEARS!! If if pick the block I get this Command: gatte Initializing... Select block or attribute [block name]: Block: Meridian_a1_sheet Attribute tag: TUK-SUB-TY-NO Enter new text: *Cancel* and I can then type in the changes Command: `*Cancel* if I try to do it on the command line - I get this Command: GATTE Select block or attribute [block name]: b Enter block name: Meridian_a1_sheet Known tag names for block: REV_6_DATE REV_6_APP REV_6_CONTRACT REV_6_COMPANY REV_6_CHECKED_BY REV_6_BY REV_6_DETAIL REV_6 REV_5_DATE REV_5_APP REV_5_CONTRACT REV_5_COMPANY REV_5_CHECKED_BY REV_5_BY REV_5_DETAIL REV_5 REV_4_DATE REV_4_APP REV_4_CONTRACT REV_4_COMPANY REV_4_CHECKED_BY REV_4_BY REV_4_DETAIL REV_4 REV_3_DATE REV_3_APP REV_3_CONTRACT REV_3_COMPANY REV_3_CHECKED_BY REV_3_BY REV_3_DETAIL REV_3 REV_2_DATE REV_2_APP REV_2_CONTRACT REV_2_COMPANY REV_2_CHECKED_BY REV_2_BY REV_2_DETAIL REV_2 REV_1_DATE REV_1_APP REV_1_CONTRACT REV_1_COMPANY REV_1_CHECKED_BY REV_1_BY REV_1_DETAIL REV_1 REV_MAIN SUP-DWG-NAME SUPPLIER_NUMBER DESIGNER TUK-SUB-TY-NO TITLE_3 TITLE_2 TITLE_1 PROJECT_NAME Select attribute or type attribute name: project_name *Invalid selection* Expects a point or RE I was very confused as what is RE? but its the first two characters of REV_6_DATE in the list of known tags sometimes I get a list like REV_6_DATE/REV_6_APP/REV_6_CON but even then typing in REV_6_DATE does not enter the text into that attribute tab - whats gone wrong with GATTE in MAP2009 Steve Muller New Zealand Quote Link to comment Share on other sites More sharing options...
NZ Steve Posted November 4, 2009 Author Share Posted November 4, 2009 Having compared some other files the only thing different I can see is the Variable DBMOD. - though this is a read only variable. Quote Link to comment Share on other sites More sharing options...
SteveK Posted November 4, 2009 Share Posted November 4, 2009 Hello, When it comes up with Expects a point or RE basically it is the start of your list of attributes but it can't fit it on the screen. eg. if you type (initget "Hello there") (nentselp) "w" It will return Expects a point or hello/ther. As for your other GATTE trouble, you might have to post the drawing (if it's small). Quote Link to comment Share on other sites More sharing options...
NZ Steve Posted November 4, 2009 Author Share Posted November 4, 2009 Yup Steve - it sure does Select object: "w" *Invalid selection* Expects a point or Hello/ther Drawing attached. Cheers Steve Muller gatte-dwg.dwg Quote Link to comment Share on other sites More sharing options...
NZ Steve Posted November 4, 2009 Author Share Posted November 4, 2009 OK - its something to do with the DWG not my system. I inserted another companies title block into the same DWG above and I can use GATTE like its spoze to. Steve M Quote Link to comment Share on other sites More sharing options...
SteveK Posted November 4, 2009 Share Posted November 4, 2009 Hi, Further digging around in the help file for initget has found the source of the problem: Each keyword can contain only letters, numbers, and hyphens (-). For example: (initget "hel_lo there") (nentsel) "he" will output: *Invalid selection* Expects a point or he Gatte uses this. So alternatives for you are to either select the attribute (rather than the block) or I made a program called gatte2 which doesn't use initget you might try instead. Quote Link to comment Share on other sites More sharing options...
NZ Steve Posted November 4, 2009 Author Share Posted November 4, 2009 Yup - correct all the attributes in the titles are like DFD_No_10 - looks like a little edit time for me - thanks muchly Steve M Quote Link to comment Share on other sites More sharing options...
CeeCrown Posted September 21, 2017 Share Posted September 21, 2017 I had same issue with Invalid Selection, I found a solution (that worked for me) on another post: "Sometimes adding an _underscore in front of the tag works" Quote Link to comment Share on other sites More sharing options...
