dragonpace Posted November 7, 2009 Posted November 7, 2009 I am using autocad 2010 and I am not able to save edits to my user profile and my profile will not remain the default profile when I start up new sessions? suggestions please Quote
lpseifert Posted November 7, 2009 Posted November 7, 2009 Use the profile switch /p in your startup icon on your desktop. http://www.hyperpics.com/downloads/resources/customization/general/AutoCAD%20Icon%20Switch.pdf Quote
Strix Posted November 8, 2009 Posted November 8, 2009 Some establishments may have the system locked out so you can't save changes to the profile Quote
dragonpace Posted November 9, 2009 Author Posted November 9, 2009 I may not have explained my issue enough. When I loaded 2010 there was no problem with saving setting to my profile and when I started up cad every morning my profile came up and off to work I went. But I loaded the 2010 update and now when I start every morning I get the 2010 default profile and and any change that I have made to my profile setting are missing. I have gone to options and selected my profile and all of the previous days setting are gone. I corrected the profile and then saved it over the old one. Re-loaded the profile worked for the day with no problems. Get to work the next day and I have to start all over, the setting are all kaput. Thus having to start the process all over again. Quote
rkent Posted November 9, 2009 Posted November 9, 2009 Does the location of your profiles look like this one C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2010\R18.0\enu\Support\Profiles and Does your Startup Icon properties look like this "C:\Program Files\Autodesk\ACADM_2010\acad.exe" /p your profile name here /W " Assuming XP OS. Quote
dragonpace Posted November 9, 2009 Author Posted November 9, 2009 startup properties? (no clue how to get to that) and no profile location is... C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2010\enu\Support\Profiles Quote
dragonpace Posted November 10, 2009 Author Posted November 10, 2009 I find nothing with the path that you wrote for the start icon properties Quote
rkent Posted November 10, 2009 Posted November 10, 2009 startup properties? (no clue how to get to that) There should be a shortcut icon on your desktop. Hit the Windows key + M, everything will be minimized leaving you with just your desktop, locate the AutoCAD startup icon, right click, pick properties, add the /p your-profile-name in the target statement under the shortcut tab, pick OK to back out of that. Close Autocad if is up, now double click on the shortcut you just modified. Your profile will be used on startup. Quote
dragonpace Posted November 10, 2009 Author Posted November 10, 2009 ok I got the icon switch thing figured out but cad will still not save the last profile settings. I saved over and even created a new profile but setting will not save. Quote
dragonpace Posted November 10, 2009 Author Posted November 10, 2009 ok well for what ever the reason things are working again Quote
dragonpace Posted November 10, 2009 Author Posted November 10, 2009 last issue if any one can it is about printing... we have had no problems printing in 2007 but now when we print in 2010 it takes almost 3 minutes to bring up the plot model box and then we select what we want to print it takes another 3 or more minutes then it prints. How do I get this to speed up? yes we are on a network. Quote
dragonpace Posted November 10, 2009 Author Posted November 10, 2009 all of the users have the same problem Quote
