I have a set of plot pen styles I'm using from another project. Everything is working but the Center2 line will not print out correctly. It was originally set as color # 243 but is now #205 - other than that, no changes.
I can pull a rectangle window around it and plot from that, for today. But to turn in these drawings I have to have plotted ARCH D with titleblock and etc.
Need help please...:?
Open the CTB and see what other settings there are for #205, maybe it was set to 0% screening, etc.
Weird - just checked this -
the ctb is set to 100% screening; weight .1300mm; type: 'use object line type'; and Adaptive is On.
Any other tricks? This is driving me mad...
OMG, I've tried everything LTSCALE in the command line, no change to the paper space for plotting - still a solid line. Tried changing various elements in the ctbs - on my pen styles Properties...
Please, please let me know if there is anything else I can try.
I may have misunderstood your original post. You wrote that it wasn't plotting, I took that to mean it wasn't showing at all, but sounds like you mean the line type is showing only as a solid line, and only in PS. Is that correct?
In PS set ltscale to 0.5, psltscale to 1. Now go into the viewport and make sure Shademode is set to 2D.
Fantastico! thank you so much for your response!
