I'm still getting the error below, it doesn't appear to be selecting the line.
Command: _.pedit Select polyline or [Multiple]: Select polyline or
[Multiple]: _L
Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype
gen/Undo]: on
Invalid option keyword.
  • Replies 48
  • alanjt
    25
  • LtRimmer
    24
[Multiple]: _L
gen/Undo]: on
Oops, forgot the "" to end the selection.
(vl-cmdf "_.pedit" #Ent "" "_L" "on" "")
I'm still getting the same error, does it matter where I add the line?
Show me what you have, I'm traveling blind.
Sorry, I went back to your original code just in case it was caused by the changes I made.
(defun c:test (/ #Entlast #Ent #Obj #Length #LType #Value)
 (vl-load-com)
 (or (setq #Entlast (entlast)) (setq #Entlast T))
 (vl-cmdf "_.pline")
 (while (not (zerop (getvar 'cmdactive)))
   (princ "\nSpecify next point: ")
   (vl-cmdf PAUSE)
 ) ;_ while
 (cond
   ((not (eq #Entlast (setq #Ent (entlast))))
    (setq #Obj    (vlax-ename->vla-object #Ent)
          #Length (vla-get-length #Obj)
          #LType  (strcase (vla-get-linetype #Obj))
    ) ;_ setq
    (cond
      ;; 4-2
      ((eq #LType "4-2") (setq #Value (+ (* (fix (/ (- #Length 4) 6)) 6) 4)))
      ;; 1-5
      ((eq #LType "1-5") (setq #Value (+ (* (fix (/ (- #Length 1) 6)) 6) 1)))
      ;; no match
      (T (alert "No matching Linetypes!"))
    ) ;_ cond
    (and #Value
         (vl-cmdf "_.lengthen" "_total" #Value (list #Ent (getvar 'lastpoint)) "")
         (princ (strcat "\nNew Length: " (vl-princ-to-string #Value)))
    ) ;_ and
 ) ;_ cond
 [b](vl-cmdf "_.pedit" #Ent "" "_L" "on" "") [/b]
) ;_ defun
Try this:
 (vl-load-com)
 (vl-cmdf "_.pline")
   (vl-cmdf PAUSE)
 ) ;_ while
 (cond
    ) ;_ setq
    (cond
      ;; 4-2
      ;; 1-5
      ;; no match
    ) ;_ cond
    (and #Value
         (vl-cmdf "_.pedit" #Ent "_L" "on" "")
    ) ;_ and
 ) ;_ cond
) ;_ defun
Sorry to be a pain, I did try it in there and just again but I still get the same error as if nothing is selected.
Is the layer locked? It works fine on my end; no errors.
Set cmdecho to 1, then try it again and paste exactly what it does.
See below, and the layer is unlocked.
Command: test
_.pline
Specify start point:
Specify next point:
Current line-width is 0.1000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Specify next point:
Specify next point:
Specify next point:
Command: _.lengthen
Select an object or [DElta/Percent/Total/DYnamic]: _total
Specify total length or [Angle] : 64
Select an object to change or [undo]:
[Multiple]: _L
gen/Undo]: on
gen/Undo]:
Command:
New Length: 64
Command:
How odd!
Try this: :?
 (vl-load-com)
 (vl-cmdf "_.pline")
   (vl-cmdf PAUSE)
 ) ;_ while
 (cond
    ) ;_ setq
    (cond
      ;; 4-2
      ;; 1-5
      ;; no match
    ) ;_ cond
    (and #Value
         (vl-cmdf "_.pedit" (list #Ent (getvar 'lastpoint)) "_L" "on" "")
    ) ;_ and
 ) ;_ cond
) ;_ defun
If this doesn't work, shoot me a sample drawing.
It's still the same, see attached drawing.
Would it be an issue with 2008, as I'm not currently at my 2009 machine.
I seriously doubt it.
I'm at a complete loss. Going to have to think about this one.
Works fine for me.
Enter new value for CMDECHO <0>: 1
Command: TEST
_.pline
Specify next point:
Specify next point:
Specify next point:
Specify next point:
Specify next point:
Command: _.lengthen
Specify total length or [Angle] <4.00)>: 4
gen/Undo]: _L Enter polyline linetype generation option [ON/OFF] <On>: on
gen/Undo]:
Command:
New Length: 4
Very strange, I'll try it on a different machine (just in case)
Try this:
 (vl-load-com)
 (vl-cmdf "_.pline")
   (vl-cmdf PAUSE)
 ) ;_ while
 (cond
    ) ;_ setq
    (cond
      ;; 4-2
      ;; 1-5
      ;; no match
    ) ;_ cond
    (and #Value
         (vl-catch-all-apply 'vla-put-linetypegeneration (list #Obj :vlax-true))
    ) ;_ and
 ) ;_ cond
) ;_ defun
Just tried it on our 2009 machine and both versions work great, however both versions do not work on the 2008 machine. I can't tell if it's the machine or 2008 as we only had one 2008 machine available today, unfortunately most of our machines run 2008.
You tried the version that does NOT have the pedit command? Version shouldn't matter anymore. I'm setting the linetype generation with vla.
What's it doing now?
Both version do not work on the 2008 machine, you just don't see the error message with the vla version any more.
I'm currently sitting in front of both PC's if you can think of anything to try.
Now?
 (vl-load-com)
 (vl-cmdf "_.pline")
   (vl-cmdf PAUSE)
 ) ;_ while
 (cond
    ) ;_ setq
    (cond
      ;; 4-2
      ;; 1-5
      ;; no match
    ) ;_ cond
    (and #Value
         (vl-catch-all-apply 'vla-put-linetypegeneration (list #Obj :vlax-false))
    ) ;_ and
 ) ;_ cond
) ;_ defun
