m4rdy Posted November 13, 2009 Posted November 13, 2009 Fixo, Your DBM helps me alot. I will use it probably almost every day to finish my job (my daily work). Is it possible to get data back from drawing to excel with exactly formating like example excel file on those thread. I need that because I want to collect the data from all previous drawings i have. Perhaps like 'vice-versa' of DBM, but i don't have any clue with lisp. Thank you. mardi Quote
fixo Posted November 13, 2009 Posted November 13, 2009 Fixo,Your DBM helps me alot. I will use it probably almost every day to finish my job (my daily work). Is it possible to get data back from drawing to excel with exactly formating like example excel file on those thread. I need that because I want to collect the data from all previous drawings i have. Perhaps like 'vice-versa' of DBM, but i don't have any clue with lisp. Thank you. mardi Mardi, I will try to rewrite it for your needs but right now I haven't have a time - there is to much another work for me I will write you private message here when I will be free Keep watching PM box above ~'J'~ Quote
rahoul85 Posted July 6, 2010 Posted July 6, 2010 how it is done can anybody help me? Can excel sheet be linked to Auto Cadd like if we change the values in excel sheet that should automatically change the dimensions in autocadd drawings Quote
rahoul85 Posted July 6, 2010 Posted July 6, 2010 if it is possible , then please teach me............. Quote
avguy Posted January 10, 2011 Posted January 10, 2011 if it is possible , then please teach me............. You can Google for "Autocad datalink" which is what you need. Quote
ABUSAIF Posted October 16, 2012 Posted October 16, 2012 Hi Fixo, I was very impressed with the code you wrote for Mardi, I been trying to do something similar for a long time but never succeed, I drew retaining wall (posts and panels) the panels are standard size rectange and the posts are H beam, what Im trying to do is to type in excel the bottom of wall elevation and the top of wall elevation with a fixd options like max width for the panel and max spacing for the post.. minimum embedment in ground etc.. do you think you can help me with this, thanks in advance. Sam Quote
ABUSAIF Posted October 16, 2012 Posted October 16, 2012 Hi Fixo, I was very impressed with the code you wrote for Mardi, I been trying to do something similar for a long time but never succeed:( , I drew retaining wall (posts and panels) the panels are standard size rectange and the posts are H beam, what Im trying to do is to type in excel the bottom of wall elevation and the top of wall elevation with a fixd options like max width for the panel and max spacing for the post.. minimum embedment in ground etc.. do you think you can help me with this, thanks in advance. Sam Quote
BIGAL Posted October 17, 2012 Posted October 17, 2012 My 5 cents worth is there a need for excell at all why not design a front end that handles all the questions it can have look up tables etc for bar sizes Quote
ABUSAIF Posted October 19, 2012 Posted October 19, 2012 Hi Begal, How diid you get this window? Im using Autocad 2013 Quote
BIGAL Posted October 22, 2012 Posted October 22, 2012 Abusaif I wrote the code for it. There used to be an example called SHAFT that was shipped with Autocad you changed a value in excell your drawing changed, its a pity Autodesk dropped it. The example would answer all the questions and it was done in lisp. Quote
ABUSAIF Posted October 24, 2012 Posted October 24, 2012 Bigal, thanks for your reply, do you think you can share the code with me?ThanksAbusaif Quote
ABUSAIF Posted October 24, 2012 Posted October 24, 2012 Bigal, Thanks for your reply, can you send me the code?ThanksAbusaif Quote
ABUSAIF Posted November 7, 2012 Posted November 7, 2012 Bigal, can you share the lisp you have to create this window, will you ba able to help me modify it. I really appreaciate it.. Quote
jaypatel187 Posted June 24, 2013 Posted June 24, 2013 How to draw reinforcement for beam. kindly send the lisp file for drawing reinforcement. Quote
jaypatel187 Posted June 28, 2013 Posted June 28, 2013 Can you please upload a code to draw reinforcement. I want to develop program for column and slab. so for reference i want the beam detailing program including reinforcement. Quote
