Problem: QSave changes the Visual Style
Got a problem and I've tried for two days to figure this out.... everything I Ctrl+S it switches the Visual Style to 3DWireframe and PERSPECTIVE variable is set to 1. I don't think it's a problem with the Visual Style, I think it's a problem with the PERSPECTIVE Variable, since you can't be in 2DWireframe mode and have a non-orthographic perspective on.
Any ideas? I've tried looking at the View defaults, I've tried resetting the UCS to World, I can't seem to get it going. Thanks in advance.
My first inclination would be to check the CUI and make sure that key combination isn't set to do more than save. What does .qsave do to your setup?
rkent, thanks for the help.
When I type .qsave at the command line, it does the same thing. Nothing changes as far as my workspace or my CUI file, that I know of. I'll snoop around in my CUI settings and see if I see anything that is unfamiliar....
