Hello,
Looking for help exporting coordinate information to an Excel file. I would like to select a series of dots and polylines in AutoCAD LT 2009 and export them to Excel in the format shown. Currently I use list and manually enter the data into a tab delimited text file, but if I can get the info into excel, I can cut that step out and manipulate it easier. Thanks!!!
Forum Ref.dwg
Excel Format.doc
Hello,
You will probably get a better response and program from another member but my suggestion you could try CadTools by www.glamse.se its a free drainage and engineering type progam that interacts with AutoCad. You can export lines, blocks etc.. (although separately to different files)..among other nice things.
Hello,
I have just A2008 on my machine
this one is worked good for me
Not sure about if it will be work on LT
~'J'~
dwgtoexcel.LSP
www.glamse.se Duh?
no such animal
  • 1 year later...
