Out of memory in VidLib
Hi!
I'm using novapoint Virtual Map. And when I try to build the model for the viewer, I usually get the message in the attached file
I can't find the file the error should be in either (Array.cxx)
Does anyone know what's to do to fix this?
If you need some more info, just ask ^^
Did you try increasing virtual memory?
Just for my education what is Novapoint Virtual Map?
Novapoint (it comes in several variations) is an application to AutoCAD for water/sewage, district heating, roads, railroads... so the website says. The company operates almost exclusively in Scandinavia I believe.
I use Novapoint for District heating, basically you draw in 2D and in the end you get a 3D-representation of your pipes. And you also get an automated elevation of the pipes, which is really the big win with this since that is what takes a boatload of time to do.
Virtual Map is in the same way an application to work in 2D in normal AutoCAD and in the end get a 3D model of your project. We don't yet have Virtual Map here so I can't help :(
Thanks for educating me Tiger. :)
Scorpier: Can we have your system specs please?
