kyskiz Posted November 17, 2009 Posted November 17, 2009 Hello Newbie acad user is here again, need ur help I wanna ask if there is any way to delete only a part of drawing, lets say circle i know that i can use 'AddArc' but those parts are not even* so it would be hard to make them. so the main question is can i delete only a part of circle or line, and if yes, could anyone post a few lines explaining how should i do that? Thank you in advance, Acad newbie user *even/equal, dunno which word fits here better Doesnt anyone have any ideas ? Or it just cant be done? Quote
SEANT Posted November 18, 2009 Posted November 18, 2009 It sounds like you are trying to automate the “Trim” command. If so then you will likely be disappointed in that VBA does not have a built in Trim method. And, as you have already determined, entities that change when trimmed would have to be recreated. The good news is that an arc has common parameters as a circle, i.e., center, radius. The start and end angle would need to be calculated from the info returned by IntersectWith. Quote
