RaymondR Posted August 6, 2008 Share Posted August 6, 2008 Morning, I have Inventor 2009, and in a project I am trying to constrain two objects together using the X axis (no problem here) and an angled surface - both at 45 degrees. As I try and add the constraint it seems as though nothing happens. When I apply other constraints the parts will "snap" into place, but for the angled surface it won't. See the attached picture. This is an example of what I am trying to fit together. I found the contact solver, and that works to move the parts until they stop, but once they contact I would like them to "stick", so to speak. Thanks! Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 6, 2008 Share Posted August 6, 2008 Sketch a horizontal line across the v at the contact point in each part and place an assembly constraint with the lines. If you can't figure it out post what you have so far. Quote Link to comment Share on other sites More sharing options...
RaymondR Posted August 6, 2008 Author Share Posted August 6, 2008 That worked, although I would have thought there would be something a bit more automatic... Thanks! Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 6, 2008 Share Posted August 6, 2008 When I am creating parts like this I derive the sketch from the first into the second - so it is already done as I go. Quote Link to comment Share on other sites More sharing options...
RaymondR Posted September 8, 2008 Author Share Posted September 8, 2008 I ended up contacting Autodesk support regarding this question. They sent me a video that shows a successful mate along the angled surface. It seems that if you just pick the conical surface it does not select the right surface to use. You will need to hover over the cone surface, allow the select other arrows to appear, select the right button until it selects the surface without the center line, then the other surface it is to mate to. This will accomplish the exact result I was after and there was no need to add additional sketch geometry. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted September 8, 2008 Share Posted September 8, 2008 you got it, i was going to say you need to use the selection list or sort so you can select the correct surface. Quote Link to comment Share on other sites More sharing options...
