diablo98 Posted November 23, 2009 Posted November 23, 2009 Hi everyone, I'm trying to create own linetype in autocad. I need continuous line but with dots on vertex (see attached image). So, any ideas? Quote
CarlB Posted November 23, 2009 Posted November 23, 2009 Not possible with an AutoCAD linetype, it doesn't handle variable spacing. One way to achieve that look, is to make a block consisting of a wipeout and a dot (zero or short length line), and copy it to every vertex. Quote
diablo98 Posted November 23, 2009 Author Posted November 23, 2009 Not possible with an AutoCAD linetype, it doesn't handle variable spacing. One way to achieve that look, is to make a block consisting of a wipeout and a dot (zero or short length line), and copy it to every vertex. Thx for the answer... I've tried everything...so it's not possible...now is official! Quote
rkmcswain Posted November 23, 2009 Posted November 23, 2009 You might check to see if these guys can make it happen... http://www.autodsys.com/autoline.html Quote
