mohsen Posted November 25, 2009 Share Posted November 25, 2009 How do I change the measurement dimension value? example: i have 14 in dimension value and I want to change it to 5, is it possible?? Quote Link to comment Share on other sites More sharing options...
mohsen Posted November 25, 2009 Author Share Posted November 25, 2009 I've just found the way! lol tnx 2 all anyway Quote Link to comment Share on other sites More sharing options...
Tankman Posted November 25, 2009 Share Posted November 25, 2009 I've just found the way! lol tnx 2 all anyway Welcome to the forums mohsen! Where are you posting from? My, that was easy. And, why did you want to change the dimension from 14 to 5? Quote Link to comment Share on other sites More sharing options...
mohsen Posted November 25, 2009 Author Share Posted November 25, 2009 it was just an example, i wanted 2 edit the value! Quote Link to comment Share on other sites More sharing options...
Tankman Posted November 25, 2009 Share Posted November 25, 2009 it was just an example, i wanted 2 edit the value! If the part(s) is not changing, Modify>Properties>Text Override. Whatever? Quote Link to comment Share on other sites More sharing options...
bonehead411 Posted November 25, 2009 Share Posted November 25, 2009 How do I change the measurement dimension value? example: i have 14 in dimension value and I want to change it to 5, is it possible?? Welcome to the forums mohsen, but I have to say.....fudging dimensions is frowned upon around here, leads to all kinds of complications..... Quote Link to comment Share on other sites More sharing options...
mohsen Posted November 25, 2009 Author Share Posted November 25, 2009 hi again thats not the way u think my friend, tnx for reply Quote Link to comment Share on other sites More sharing options...
Tiger Posted November 25, 2009 Share Posted November 25, 2009 Mohsen, no harshness against you, but you willl notice if you stay around here (which I hope) that not only will get you advice on how to use AutoCAd, but also how to be a bettter drafter. Which is why Bonehead commented like he did. And I will second his comment. In my opinion, there are very few reasons to override a dimension... Quote Link to comment Share on other sites More sharing options...
mrbucket Posted November 25, 2009 Share Posted November 25, 2009 Welcome to the forums mohsen! Where are you posting from?My, that was easy. And, why did you want to change the dimension from 14 to 5? Welcome to the forums mohsen, but I have to say.....fudging dimensions is frowned upon around here, leads to all kinds of complications..... Mohsen, no harshness against you, but you willl notice if you stay around here (which I hope) that not only will get you advice on how to use AutoCAd, but also how to be a bettter drafter. Which is why Bonehead commented like he did. And I will second his comment. In my opinion, there are very few reasons to override a dimension... ^ Like all have said. The most you want to change is the precision. Quote Link to comment Share on other sites More sharing options...
bonehead411 Posted November 26, 2009 Share Posted November 26, 2009 In my opinion, there are very few reasons to override a dimension... Agreed. If the geometry is right, the dimension will be too. If the geometry is not right, make it so. Otherwise, how can you be sure it will work? And yes, I speak from experience! Quote Link to comment Share on other sites More sharing options...
chauhanvikash Posted December 28, 2009 Share Posted December 28, 2009 just select and edit the dimension Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 28, 2009 Share Posted December 28, 2009 In 2010 if you use geometry constraints and parametric dimensions you can double click on dimension to edit and your geometry will update automatically. Quote Link to comment Share on other sites More sharing options...
