Hello People!
I have a little question for you guys..
The problem is that i have to make a 3d render image of something i designed. Everything goes well untill the rendering itself.. When i randomly render some things, it all goes well, but when rendering the object I actually want to render ( and zooming in on it), it shows me a black screen in the render view! But! When i zoom a little more out, change a few times from viewpoints and then render, i do see a rendered image! Then if i zoom in again it shows me the black screen again! I already added pointlights, spots and sunlight, but I still get a Black screen..
Can someone please help me with this? Its just that Autocad gives me the feeling it does what it wants.. and there's no reason for it!
greets,
Caske.
  • 5 months later...
I recently had the same trouble with "black" renderings, I searched it on the net, and it seems that Autocad has a little bug...
Here is the best solution (it worked for me)
Type "3DORBIT" then right click and select "Zoom extends" from the menu and press "Enter". Finally select "Regen all" from the View menu and you are ready to procceed with your rendering.
