I actually have a number of issues but, I am a student and need some answers. When I try to print in 3D Wireframe, conceptual or realistic thte contents of the viewport come out either 2D wireframe, 3D wireframe with missing lines, a solid mass, or a mixture of any 2 of the mentioned. All my layers are organized and turned on. Also when I zoom in, at some point (varies) my object goes black. I have assignments due and instructors dont seem to have an answer why I cant get a normal print done.o:)
We need to see all the parameters you use when you are plotting. Post them here.
Re: Layer Properties Manager. Are you sure all layers are set to plot and no layers have been designed not to plot?
I tried to post a copy of my layers properies manager but the file is 270kb, 220 more than aloud. Everything seems to be in the spot and unlocked. Why would the fillets be undone when I open the file? I take the bak file and rename it a DWG and open it, I have my fillets back but when I save it again and try to open the file the fillets are gone again. Even after changing the file from a bak file type back to a DWG, I open the file and its fine, if I email the file the fillats are gone when the file gets opened. Regaurdless, the viewing stye just seems to come out as what even the computers want to do at the time know matter what I want.
