Hi.
Is there an way to edit an ATT in a block?
The expirience i got is once you made an (dynamic) block with an ATT in it you cannot edit anything about it (like the location or the TAG/Prompt).
I want to change both of those, but when i save the block it stays the same. Any idea on how to change that without exploding and rebuilding the (dynamic) block?
Edit: I can edit those, but moving will not work, how can i move the ATT?
edit your block as you would normally. save your changes to your block, then use ATTSYNC on your attributes to update them.
Be careful, as if you had previously altered any of the attributes on a per block basis - using ATTSYNC will force the attributes to take on the properties and positions as determined by the block itself
