alanjt Posted December 3, 2009 Share Posted December 3, 2009 Did you not receive an error after running the code in reply #12? If so, could you post your command-line history on here so that we can diagnose it Guess I should word myself a little differently. Remember, I am American.:wink: Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 If you copied the code in post #12 onto the command line and hit enter you should receive: C:MXY Then, if you type MXY and hit enter, it should invoke the LISP function. Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 it spat out a mile long list, then gave me a ton of errors. Invalid window specification. Select objects: Specify opposite corner: Select Invalid window specification. Select objects: Specify opposite corner: objects: Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: Specify Invalid window specification. Select objects: Specify opposite corner: base Invalid window specification. Select objects: Specify opposite corner: point Invalid window specification. Select objects: Specify opposite corner: or Invalid window specification. Select objects: Specify opposite corner: [Displacement] Invalid window specification. Select objects: Specify opposite corner: : Invalid window specification. Select objects: Specify opposite corner: Specify Invalid window specification. Select objects: Specify opposite corner: second Invalid window specification. Select objects: Specify opposite corner: point Invalid window specification. Select objects: Specify opposite corner: or Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: first Invalid window specification. Select objects: Specify opposite corner: point Invalid window specification. Select objects: Specify opposite corner: as Invalid window specification. Select objects: Specify opposite corner: displacement>: Invalid window specification. Select objects: Specify opposite corner: *Cancel* Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: Command: Invalid window specification. Select objects: Specify opposite corner: *Cancel* Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: Command: Invalid window specification. Select objects: Specify opposite corner: *Cancel* Invalid window specification. Select objects: Specify opposite corner: Invalid window specification. Select objects: Specify opposite corner: Command: Invalid window specification. Select objects: Specify opposite corner: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> ) (((((((((_> C:MXY (((((((((_> (((((((((_> Command: (((((((((_> .MOVE misplaced dot on input Specify opposite corner: Select Invalid window specification. Select objects: Specify opposite corner: objects: Invalid window specification. Select objects: Specify opposite corner: 1 0 found Select objects: found *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Select objects: Command: Select Select objects: objects: *Invalid selection* Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P revious/Undo/AUto/SIngle/SUbobject/Object Select objects: Command: Specify Unknown command "SPECIFY". Press F1 for help. Command: base Enter base point : point Invalid point. Enter base point : or Invalid point. Enter base point : [Displacement] Invalid point. Enter base point : : Invalid point. Enter base point : Specify Invalid point. Enter base point : second Invalid point. Enter base point : point Invalid point. Enter base point : or Invalid point. Enter base point : Command: Command: first Unknown command "FIRST". Press F1 for help. Command: point Current point modes: PDMODE=34 PDSIZE=0'-3" Specify a point: as Invalid point. Specify a point: displacement>: Invalid point. Specify a point: Invalid point. Specify a point: Invalid point. Specify a point: off> Invalid point. Specify a point: *Cancel* Invalid point. Specify a point: Invalid point. Specify a point: Command: Invalid point. Specify a point: Specify Invalid point. Specify a point: opposite Invalid point. Specify a point: corner: Invalid point. Specify a point: Command: Invalid point. Specify a point: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> ) (((((((((_> C:MXY (((((((((_> (((((((((_> Command: (((((((((_> .MOVE misplaced dot on input Specify a point: Select Invalid point. Specify a point: objects: Invalid point. Specify a point: 1 Command: found Unknown command "FOUND". Press F1 for help. Command: POINT Current point modes: PDMODE=34 PDSIZE=0'-3" Specify a point: Select Invalid point. Specify a point: objects: Invalid point. Specify a point: Invalid point. Specify a point: Specify Invalid point. Specify a point: base Invalid point. Specify a point: point Invalid point. Specify a point: or Invalid point. Specify a point: [Displacement] Invalid point. Specify a point: : Invalid point. Specify a point: Specify Invalid point. Specify a point: second Invalid point. Specify a point: point Invalid point. Specify a point: or Invalid point. Specify a point: Invalid point. Specify a point: Invalid point. Specify a point: first Invalid point. Specify a point: point Invalid point. Specify a point: as Invalid point. Specify a point: displacement>: Invalid point. Specify a point: *Cancel* Invalid point. Specify a point: Invalid point. Specify a point: Command: Invalid point. Specify a point: *Cancel* Invalid point. Specify a point: Invalid point. Specify a point: Command: Invalid point. Specify a point: *Cancel* Invalid point. Specify a point: Invalid point. Specify a point: Command: Invalid point. Specify a point: Command: Invalid point. Specify a point: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> )x (((((((((_> nil (((((((((_> (((((((((_> Command: (((((((((_> Command: (((((((((_> .+OPTIONS misplaced dot on input Specify a point: Tab Invalid point. Specify a point: index Invalid point. Specify a point: : Invalid point. Specify a point: 1 Command: POINT Current point modes: PDMODE=34 PDSIZE=0'-3" Specify a point: Command: Invalid point. Specify a point: Invalid point. Specify a point: .+OPTIONS Invalid point. Specify a point: Tab Invalid point. Specify a point: index Invalid point. Specify a point: : Invalid point. Specify a point: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> )*Cancel* (((((((((_> (((((((((_> Tab index : (((((((((_> (((((((((_> Command: .+OPTIONS misplaced dot on input Specify a point: Tab Invalid point. Specify a point: index Invalid point. Specify a point: : Invalid point. Specify a point: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> )run (((((((((_> nil (((((((((_> (((((((((_> Command: .+OPTIONS misplaced dot on input Specify a point: Tab Invalid point. Specify a point: index Invalid point. Specify a point: : Invalid point. Specify a point: (defun c:mxy (/ ss ptso ptre ptd) ;Move in X,Y only (_> (_> (setvar "cmdecho" 1) ((_> (_> (setq ss (ssget)) (((_> (_> (setq ptso (getpoint "\n Select source point")) ((((_> (_> (setq ptre (getpoint "\n Select destination reference")) (((((_> (_> (setq ptd (list (car ptre) (cadr ptre) (caddr ptso))) ((((((_> (_> (command "_.move" ss "" "_non" ptso "_non" ptd) (((((((_> (_> (setvar "cmdecho" 1) ((((((((_> (_> (princ) (((((((((_> (_> ) (((((((((_> C:MXY (((((((((_> (((((((((_> Tab index : 1 (((((((((_> (((((((((_> *Cancel* Function cancelled Specify a point: Command: Command: POINT Current point modes: PDMODE=34 PDSIZE=0'-3" Specify a point: Command: Specify opposite corner: Command: mx Unknown command "MX". Press F1 for help. Command: Command: *Cancel* Command: *Cancel* Command: _close Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 read the previous reply, I will give that a try. thanks all Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 that works for to make you not move in a z axis. What I really would like is to make it where you can hit mx- and only move in the x axis, my...y axis and what not. Thanks for the help, I am very new to altering lisps. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 So am I right in saying that the LISP works for you now? Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 yes, I was missing that mxy at the end! Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 Well, the only thing I changed was: (command ".move" ss "" "_non" ptso "_non" ptd) to (command "[color=Red]_[/color].move" ss "" "_non" ptso "_non" ptd) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 So I assume Ms kleinchester is running a foreign version of ACAD... Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 that works for to make you not move in a z axis. What I really would like is to make it where you can hit mx- and only move in the x axis, my...y axis and what not. Thanks for the help, I am very new to altering lisps. Give this thread a look, I posted a couple routines for moving along x/y. http://www.cadtutor.net/forum/showthread.php?t=41545 Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 So I assume Ms kleinchester is running a foreign version of ACAD... LoL Lee, is going to become attached to your name, as much as you use it. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 ..... .. Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 ..... .. LoL......... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Hahaha... your photoshop skills are off the chart... impressive. Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 Hahaha... your photoshop skills are off the chart... impressive. LoL I totally butchered the bottom of it. Magic Lasso isn't very smart and I'm just lazy. Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 Thanks for the help and the smart ass comments! I have a lot to learn! Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 Thanks for the help and the smart ass comments! I have a lot to learn! We're more about being jerks than helping. :wink: Did you look at the link I posted? Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 yeah, its good stuff, I am watching the video now! Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 It makes the learning fun! Quote Link to comment Share on other sites More sharing options...
kkleinchester Posted December 3, 2009 Author Share Posted December 3, 2009 I took what I orginally posted to you after I loaded what you gave em, inserted it to the cmdline and shazam I am back in action! Did you self teach yourself this code or did you take some sort of class? Quote Link to comment Share on other sites More sharing options...
