i know this is probably a simple question I'm just looking for the command that clears all selection sets. I appreciate the help!
That didnt seem to clear the active SS. I just need a command to run before a macro that uses the "p" command.
Maybe I don’t understand. If you clear all selection sets then the “P” (previous) option will not find any selection sets.
What Lee posted should work.
Well - it clears the visible selection, but if a selection set has been created, perhaps using ssget, then previous will still detect it.
Of course, it's the last thing that was selected. Wait, what was the question? I'm dumb. LoL
Actually it is not a real simple one.
I think that you are going have to:
    Create an temporary entity
  • Create an empty selection set (ssadd)
  • Add the last entity to the empty selection set
  • Erase the selection set
To get back to the 'No previous selection set' message. -David
How about (sssetfirst)(ssadd); ? Seems to work, clears visible selection and then creates an empty ss. So far so good thank you!
Nice idea! :)
Hmmm, that didn't clear the "previous" for me...maybe my AutoCAD has a good memory.
The following might work for you.
(defun clearprevss ()
 ;; Written by AutoDesk Bonus Tools R14
 ;; ClearPrevSS - clears the previous selection set by
 ;; executing the select command and then performing an undo 1.
 ;; This function does not verify that undo is enabled and will
 ;; fail if undo is disabled.
 (if (entnext)
   (progn (command ".select" (entlast) (entnext))
          (while (not (equal (getvar "cmdnames") "")) (command ""))
          (command ".undo" "1")
