any body can help or give me Registration code for PDF2DWG Importer
Please......
If you leave your credit card details someone will help you.
In a quick search of the internet, I found two companies that make converters that also offer trial versions. I tried them. They work.
That's more helpful than my comment, thanks StevJ.
PDF2DWG has been talked about before:
Apparently a Autodesk patch exists? See here
I've used this one:
http://www.cadtutor.net/forum/showpost.php?p=284211&postcount=7
Then there's others:
http://rkmcswain.blogspot.com/2006/03/convert-pdf-to-dwg.html
http://www.autodwg.com/pdf-to-dwg-converter/
