Hello all,
I am having an issue with a code that semi works. The following code works when i have only one block that is called "DBORDER_1"
Dim blk As AcadBlockReference
For Each blk In ThisDrawing.ModelSpace
If blk.Name = "DBORDER_1" Then
However when I have more than 1 block than the vba code crashes. The runtime error code is 13, type mismatch. What i am trying to do is to find the block named "DBORDER_1" and determine its attributes.
would anyone know how to remove this problem. thanks. Korhaniski
Hello all,
At the first glance you need declare AcadEntity before
i.e.
Dim oEnt as AcadEntity
For Each oEnt In ThisDrawing.ModelSpace
if Typeof oEnt Is AcadBlockReference Then
Set blk=oEnt
< the rest code goes here>
End If
End If
Next oEnt
~'J'~
Ahhh awesome thanks bunch i owe u cofee ~'J'~
You're quite welcome
(Remember use AcadEntity in loops)
~'J'~
