Would it be wise to put a full floor plan on Arch C 18x24"?
Only if that is the size that your custom wants. The typical sizes are 22x34 or 11x17.
We use 24x36, 18x24, and 11x17 all of the time.
If you can fit the entire floorplan on the page that size, and still be able to use a reasonable scale IE 1/4" = 1'-0" or 1/8" = 1'-0" you should be fine. About the only time I use that size sheet anymore is for small additions or very small buildings. Other than that our standard is the Arch D (24x36) or 30x42 both at 1/4 scale
Yep. Check first. What Plotter Size is your default? You can also PDF anysize if you set it up. Although- Not professional to make client plot their own.
