rengised Posted December 6, 2009 Share Posted December 6, 2009 Hi its me again, is it possibe to convert this lisp below into icon? Instead of typing the command. I got this good lisp in asmitools. Thanks to asmitools site. Thanks again guys. (princ "\n<<< Select LwPolyline for dimensioning >>> ") (if(setq plSet(ssget '((0 . "LWPOLYLINE")))) (progn (setq pLlst(vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet))) oldDss(getvar "DIMASSOC") ); end if (setvar "CMDECHO" 0) (command "_.undo" "_be") (setvar "DIMASSOC" 2) (foreach pl pLlst (setq vLst(mapcar '(lambda(x) (trans x 0 1))(mapcar 'cdr (vl-remove-if-not '(lambda(x)(= 10(car x)))(entget pl)))) ); end setq (if(equal '(70 . 1)(assoc 70(entget pl))) (setq vLst(append vLst(list(car vLst)))) ); end if (while(< 1(length vLst)) (setq cAng(angle(car vLst)(cadr vLst)) cDis(/(distance(car vLst)(cadr vLst))2)) (if(>=(caar vLst)(caadr vLst)) (setq cAng(- cAng pi)) ); end if (setq cPt(polar (polar(car vLst)cAng cDis) (+ cAng(* 0.5 pi))(* tOff (*(getvar "DIMSCALE") (getvar "DIMTXT")))) ); end setq (command "_.dimaligned" "_end" (car vLst) "_end" (cadr vLst) "_none" cPt) (setq vLst(cdr vLst)) ); end while ); end foreach (setvar "DIMASSOC" oldDss) (command "_.undo" "_e") (setvar "CMDECHO" 1) ); end progn ); end if (princ) ); end of c:pdim (princ "\n[info] http:\\\\[url]www.AsmiTools.com[/url] [info]") (princ "\n[info] Type PDIM for multiple LwPolyline dimensioning. [info]") Quote Link to comment Share on other sites More sharing options...
lpseifert Posted December 6, 2009 Share Posted December 6, 2009 I'm assuming you want to make a toolbar button. You know that all of the code isn't posted, but I think I can figure it out. In the CUI, create a new command; Use this as the macro. (if (not c:pdim)(load "LispName"));pdim; Where LispName is the name of the lisp file Quote Link to comment Share on other sites More sharing options...
