Dante Sparda Posted December 7, 2009 Posted December 7, 2009 Hi everybody, I'm doing an aplication with vba, and autocad opens automatically, always in 2d wire visual style, so I need to change it to conceptual or realistic with vba. And after I insert some blocks (in 0,0,0) they are not completely visible, so I need to zoom all, also with vba. And finally, how do I set the viewpoint to be isometric from, I'm not quite sure hot to say it, let's saay... isometric from front-right I really need this, hope anyone can help me thanks in advance!!!! Quote
fixo Posted December 7, 2009 Posted December 7, 2009 Hi everybody, I'm doing an aplication with vba, and autocad opens automatically, always in 2d wire visual style, so I need to change it to conceptual or realistic with vba.And after I insert some blocks (in 0,0,0) they are not completely visible, so I need to zoom all, also with vba. And finally, how do I set the viewpoint to be isometric from, I'm not quite sure hot to say it, let's saay... isometric from front-right I really need this, hope anyone can help me thanks in advance!!!! Not tested, maybe some mistakes here partially borrowed from Help Option Explicit Sub Test() Dim blkRef As AcadBlockReference Dim varPt(0 To 2) As Double Dim i As Integer For i = 0 To 2 varPt(i) = 0 Next Set blkRef = ThisDrawing.ModelSpace.InsertBlock(varPt, "MyBlock", 1, 1, 1, 0) Dim vdir(0 To 2) As Double vdir(0) = -1: vdir(1) = -1: vdir(2) = 1 ThisDrawing.ActiveViewport.Direction = vdir ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport Dim minExt As Variant Dim maxExt As Variant blkRef.GetBoundingBox minExt, maxExt ZoomWindow minExt, maxExt ThisDrawing.Regen acActiveViewport End Sub Quote
Dante Sparda Posted December 7, 2009 Author Posted December 7, 2009 Now the zoom thing is ready Thank you very much!! now I need to set the realistic visual style, anyone can help ne with this?? Quote
