maksolino Posted December 8, 2009 Posted December 8, 2009 Many times i need to intersect object at one coordinate I must create a plane and then find the intersection. It is possible that script do this for me? Example insert the numerical value of the coordinate select one or more object Enter Thanks Quote
maksolino Posted February 4, 2011 Author Posted February 4, 2011 Hello I made this rvb to help myself It is primitive but it works This is for Z coordinate, but i have also similar for X end for Y wourld coordinates. Can somebody make a new one whith the option to choose first the axis: X, Y or Z Thanks Option Explicit Dim object object = Rhino.GetObjects("Select object To intersect") 'create group Rhino.AddGroup("Sergio") Dim grpObjs:grpObjs=Rhino.AddObjectsToGroup(object,"Sergio") Call CutZ() Sub CutZ() Dim x, y, x1, y1 Dim z z = Rhino.GetReal("Z coordinate", 0.0) x = -100000 y = -20000 x1 =100000 y1 =20000 Dim arrPoints(3) arrPoints(0) = Array(x,y,z) arrPoints(1) = Array(x1,y,z) arrPoints(2) = Array(x1,y1,z) arrPoints(3) = Array(x,y1,z) If IsArray(arrPoints) Then Rhino.Command "-layer new ZZZ enter" Rhino.Command "-layer current ZZZ enter" Rhino.AddSrfPt arrPoints End If Rhino.Command "-layer new INTS enter" Rhino.Command "-layer current INTS enter" Rhino.Command "_intersect -SelGroup Sergio -sellayer ZZZ enter" Rhino.Command "-selnone -sellayer ZZZ cut enter" Rhino.Command "-layer delete ZZZ enter" Rhino.Command "-SelGroup Sergio -Ungroup -selnone" End Sub Quote
SEANT Posted February 5, 2011 Posted February 5, 2011 Nicely done. This has undergone limited testing but I think is heading in the direction you specified. Option Explicit Controller ' initiate controller Sub Controller Dim strObjects, strObject Dim strOrdinateOption Dim strPlane Dim dblCoord Dim arrIntersect Dim i, TotalIntersections strObjects = Rhino.GetObjects("Select object To intersect", 60) If IsNull(strObjects) Then Exit Sub strOrdinateOption =UCase(Rhino.GetString("Enter X, Y, or Z to specify intersection orientation")) If strOrdinateOption <> "X" And strOrdinateOption <> "Y" And strOrdinateOption <> "Z" Then Exit Sub Rhino.EnableRedraw (False) Rhino.AddLayer("INTS") TotalIntersections = 0 dblCoord = Rhino.GetReal(strOrdinateOption & " coordinate", 0.0) If IsNull (dblCoord) Then dblCoord = 0.0 strPlane = GeneratePlane(strOrdinateOption, dblCoord) Rhino.UnselectObjects strObjects For Each strObject In strObjects TotalIntersections = GetIntersect (strObject, strPlane, "INTS") + TotalIntersections Next Rhino.DeleteObject strPlane Rhino.EnableRedraw (True) Rhino.Print "Total Intersections found - " & TotalIntersections End Sub Function GeneratePlane(strOrdinateOption, dblCoord) Dim strPlane Dim u Dim arrPoints(3) u = 100000 If strOrdinateOption = "X" Then arrPoints(0) = Array(dblCoord,u,u) arrPoints(1) = Array(dblCoord,-u,u) arrPoints(2) = Array(dblCoord,-u,-u) arrPoints(3) = Array(dblCoord,u,-u) End If If strOrdinateOption = "Y" Then arrPoints(0) = Array(u,dblCoord,u) arrPoints(1) = Array(-u,dblCoord,u) arrPoints(2) = Array(-u,dblCoord,-u) arrPoints(3) = Array(u,dblCoord,-u) End If If strOrdinateOption = "Z" Then arrPoints(0) = Array(u,u,dblCoord) arrPoints(1) = Array(-u,u,dblCoord) arrPoints(2) = Array(-u,-u,dblCoord) arrPoints(3) = Array(u,-u,dblCoord) End If GeneratePlane = Rhino.AddSrfPt(arrPoints) End Function Function GetIntersect(strObject, strPlane, strLayer) Dim arrObjects, i i = 0 Rhino.SelectObject (strObject) Rhino.SelectObject (strPlane) Rhino.Command "_intersect", False arrObjects = Rhino.LastCreatedObjects() If Not IsNull(arrObjects) Then i = UBound(arrObjects) + 1 Rhino.ObjectLayer arrObjects, strLayer End If GetIntersect = i End Function Quote
maksolino Posted February 5, 2011 Author Posted February 5, 2011 Thanks Seant i see in the form that You are in the right direction but when i Run it i get Microsoft VBScript / Compilation error / Syntax error / Line 11, Char 32 (char &) p.s. I'm using Rhino 3 Quote
SEANT Posted February 5, 2011 Posted February 5, 2011 I can only test on Rhino 4, but I do see where the CODE tags have changed the quotation marks in my routine above. See if the attached txt file will perform better. CoordIntersect.txt Quote
maksolino Posted February 7, 2011 Author Posted February 7, 2011 Thanks a lot Now it works But we have a small problem when I select for ex. 4 items the result is four intersection on the first selected three intersections on the second two on the third and one on the last selected Best regards Quote
SEANT Posted February 7, 2011 Posted February 7, 2011 Oops. I forgot objects created during the intersection operation are preselected. Add one line to this function: Function GetIntersect(strObject, strPlane, strLayer) Dim arrObjects, i i = 0 Rhino.SelectObject (strObject) Rhino.SelectObject (strPlane) Rhino.Command "_intersect", False arrObjects = Rhino.LastCreatedObjects() If Not IsNull(arrObjects) Then i = UBound(arrObjects) + 1 Rhino.ObjectLayer arrObjects, strLayer End If Rhino.UnselectAllObjects '*****Line added to code******* GetIntersect = i End Function Quote
