I am using ACAD 2008. I have my template set up to plot AIA LWT by Object w/ all my layers set to Standard to plot black. When I use objects from within the system such as windows, there are embedded layers to plot Full Saturation in different colors which override my plot style and plot in color. What is going on and how do I fix it so the window layers don't plot color?
Any help would be greatly appreciated! Thanks!:oops:
Cant you see what layers the other objects are on and then in your plot dialog box make the changes to them? Or create a layer with the plot settings you want for the imported layers and set them to the created layer?
