Jadeous Posted December 9, 2009 Author Posted December 9, 2009 makes all the object in the drawing diappear Quote
devitg Posted December 9, 2009 Posted December 9, 2009 makes all the object in the drawing diappear It work well at ACAD 2008 WITH THE LONG RENUM Command: RENUM Type prefix: <>: 25 Type suffix: <>: LOP Enter start number <1>: 2 keep contents of the text [Yes/No] <Yes>: Paste text <exit> >> Paste text <exit> >> Can't paste to block's DText or MText. Paste text <exit> >> Can't paste to block's DText or MText. Paste text <exit> >> Quote
Jadeous Posted December 9, 2009 Author Posted December 9, 2009 Ok, If I say Yes to the last que, I get: ActiveX Server returned an error: Element not found If I select No, I get: Error. Can't pase text. Quote
Lee Mac Posted December 9, 2009 Posted December 9, 2009 makes all the object in the drawing diappear Is this the result from running the code in post #20? If it is then there is something seriously wrong... What is the command line return from running the code? If any. Quote
Jadeous Posted December 9, 2009 Author Posted December 9, 2009 The same, If I say Yes to the last que, I get: ActiveX Server returned an error: Element not found If I select No, I get: Error. Can't pase text. Quote
Lee Mac Posted December 9, 2009 Posted December 9, 2009 The same, If I say Yes to the last que, I get: ActiveX Server returned an error: Element not found If I select No, I get: Error. Can't pase text. But my code does not have any "que"... Are you sure you are loading the code properly and invoking it with "test"? Quote
Jadeous Posted December 9, 2009 Author Posted December 9, 2009 I meant que, as in the last choice asked by the lisp on the renum. The "test" lisp, it just making all of the object disappear. Quote
Lee Mac Posted December 9, 2009 Posted December 9, 2009 What is the command line return of the "test" LISP, if any? Quote
Jadeous Posted December 9, 2009 Author Posted December 9, 2009 It says "regenerating model" then go blank Quote
Lee Mac Posted December 9, 2009 Posted December 9, 2009 It says "regenerating model" then go blank There is something seriously wrong there - the "test" code is just basic code to access the attributes in a block. Quote
Jadeous Posted December 9, 2009 Author Posted December 9, 2009 Yeah, seems that way. I think in 2008, the way to recongnize an attribute in a block is very different. Quote
Lee Mac Posted December 9, 2009 Posted December 9, 2009 Well, seeing as this is the first I've heard of this kind of thing, in all the times people have used 2008, I think it is just your version... But if any others find a problem, shout. Quote
