wjp3wjp3 Posted December 9, 2009 Posted December 9, 2009 I have created blocks for reporting x & y coordinates as ordinate dimensions on our drawings. These use field expressions embedded in the fields within the block definition that report the coordinate points of the insertion points of the blocks. The expression for the x coordinate looks like this: %% Is there a way to write this formula so that it reports an absolute value all of the time (e.g. if x=-12'-3" the attribute would read 12'-3")? If not I can create two separate blocks - one for positive values and one for negative values and use an expression to negate the value of the negative one. However I am also having trouble getting this to work. The expression below works in reporting a simple subtraction: %% (this returns -1'-1" in the attribute, which is what I would expect). However when I substitute the expression for the x coordinate for the number 13 above the formula does not evaluate and I get "########" instead. Below is the expression that I am using: %%) \f "%lu4%pr2">% Any thoughts? Thanks, John Quote
wjp3wjp3 Posted December 10, 2009 Author Posted December 10, 2009 OK I figured out what I was doing wrong. For the expression to evaluate, the x coordinate of the insertion point needs to be unitless. This is the correct expression for the x coordinate: %% -John Quote
