-TJ Posted August 10, 2008 Posted August 10, 2008 Hi All, Problem in AutoCAD 2009: I need to sweep a 15mm x 22mm rectangle along a helix with a 27mm radius, 80mm pitch, 22mm long (high). The attached images illustrate what is happening when I try to sweep the rectangle - Image #1 is a wireframe I made to show what the swept polyline should look like. Image #2 is the result of the sweep, when picking the vertically oriented rectangle on the right of the small circle to sweep along the helix highlighted in image #1. AutoCAD is first rotating my rectangle -90° in the USC indicated X plane, and also rotating it +25.xxx° in the UCS indicated Y plane before performing the sweep. Any ideas? Alternately is there a way to turn my wireframe 4 helix "corners" and 2 rectangles (capping the helix's) into one solid? Thanks for any help! -TJ Quote
-TJ Posted August 10, 2008 Author Posted August 10, 2008 I think I got it - after another hour of playing around, I abandoned the SWEEP command and used LOFT instead; Picking my wireframe rectangles, then using the 4 helix's as Guides. Never had any use for LOFT, SWEEP, or HELIX before yesterday. HUGE thanks to CADTutor where I found [nearly] all the help I needed! -TJ Quote
Strix Posted August 11, 2008 Posted August 11, 2008 sorry you didn't get any replies, but thanks for reporting back your solution we're usually pretty quiet here at weekends as most people post from work! Welcome to CADTutor btw Quote
