nkgedadknr Posted December 12, 2009 Posted December 12, 2009 Hi All! I have a bit trouble with this I try to get Polyline properties from Cad pass to Excel by: 1. Macro Capture (Right click Popup Menu from Excel > Capture) to select Polyline in Acad. Import required properties to Excel. Then, I make Highlight polyline with propertities located at row n (Excel screen) in Acad screen and zoom to Polyline location by Zoom Center: My alorythm is to select all entities in active drawing, select entity that has same handle with one in Excel > highllight and zoom to 2. Macro Highlight (Right click Popup Menu from Excel > Hightlight) I attach a workbook and a drawing For Polyline that I draw by myself, macro Highlight do well: ie. highlight polyline and zoom correctly. (in my drawing is layer 0) Otherwise, for polyline I convert from existing line (layer 1) macro Highlight can not do properly I verify this by Debug.print objEnt.Coordinates in Macro Highlight Please help me this trouble. And other, how can I highlight a entity with grid on at 2 ends and center of an entity? This my link :Hi All! I have a bit trouble with this I try to get Polyline properties from Cad pass to Excel by: 1. Macro Capture (Right click Popup Menu from Excel > Capture) to select Polyline in Acad. Import required properties to Excel. Then, I make Highlight polyline with propertities located at row n (Excel screen) in Acad screen and zoom to Polyline location by Zoom Center: My alorythm is to select all entities in active drawing, select entity that has same handle with one in Excel > highllight and zoom to 2. Macro Highlight (Right click Popup Menu from Excel > Hightlight) I attach a workbook and a drawing For Polyline that I draw by myself, macro Highlight do well: ie. highlight polyline and zoom correctly. (in my drawing is layer 0) Otherwise, for polyline I convert from existing line (layer 1) macro Highlight can not do properly I verify this by Debug.print objEnt.Coordinates in Macro Highlight Please help me this trouble. And other, how can I highlight a entity with grid on at 2 ends and center of an entity? HTis my link : .cadviet.com/upfiles/2/upkc121209.rar Quote
SEANT Posted December 12, 2009 Posted December 12, 2009 You are better off doing this: . . . . . . ma = Range("H" & dong).Value AppActivate "AutoCAD", True With objApp Set objDoc = .ActiveDocument Dim objEnt As [color="DarkRed"]AcadEntity[/color] For Each objEnt In objDoc.ModelSpace If objEnt.Handle = ma Then objEnt.Highlight True . . . . . . If not, an error is generated whenever the routine encounters an entity other than a polyline. It just so happens that the Poly’s on layer 0 are processed before that error is encountered. Quote
nkgedadknr Posted December 14, 2009 Author Posted December 14, 2009 Thanks SEANT but it doesn't work Quote
SEANT Posted December 14, 2009 Posted December 14, 2009 As a general note, “On Error Resume Next” can be useful in areas where a programmer expects errors and needs to take steps to accommodate them. Leaving the “On Error Resume Next” active, however, will make debugging unexpected errors quite difficult. That “On Error” call should be followed by an “On Error Goto 0” as soon as possible. The modification I suggested does address one problem hidden by the situation just described. There may be additional problems; you will have to describe what does and doesn’t work more explicitly to allow us to offer useful suggestions. Quote
nkgedadknr Posted December 15, 2009 Author Posted December 15, 2009 Thanks SEANT so much, it works now, Another question concerns: I want to Zoom to Entity on Cad screen but my Zoom Center code doesn't work well, i think the problem go with the magnification. How can we choose the correct magnification adapted to desired object for zooming ? Quote
SEANT Posted December 15, 2009 Posted December 15, 2009 Here are some code modifications demonstrating how to zoom to a particular entity. These mods also show an alternate way of retrieving entities via their handles. As is commonly the case with example code, there is limited error checking and testing. Use with caution. Option Explicit Private Sub Highlight() Dim objApp As Object On Error Resume Next Set objApp = GetObject(, "AutoCAD.Application") If Err.Number <> 0 Then Err.Clear: Exit Sub On Error GoTo 0 Dim objDoc As AcadDocument Dim ma As String Dim dong As Integer dong = ActiveCell.Row ma = Range("H" & dong).Value AppActivate "AutoCAD", True With objApp Set objDoc = .ActiveDocument Dim objEnt As AcadEntity Dim varMin, varMax As Variant Set objEnt = objDoc.HandleToObject(ma) 'alternative to searching drawing database objEnt.Highlight True objEnt.GetBoundingBox varMin, varMax Dim magnification As Double magnification = CDbl(Range("J" & dong).Value) ZoomWindow varMin, varMax ZoomScaled magnification, acZoomScaledRelative End With End Sub Sub Capture() Dim objApp As Object Dim ExcCap As String ExcCap = Application.Caption On Error Resume Next Set objApp = GetObject(, "AutoCAD.Application") If Err.Number <> 0 Then Err.Clear On Error GoTo ErrHandler Set objApp = CreateObject("AutoCAD.Application") End If On Error GoTo 0 With objApp .Visible = True .WindowState = acNorm .ZoomExtents Dim objDoc As AcadDocument Set objDoc = .ActiveDocument End With With objDoc Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim oLWPline As AcadLWPolyline Dim intCodes(3) As Integer Dim varCodeValues(3) As Variant Dim dxfCode, dxfData Dim i As Integer Dim SetName As String intCodes(0) = -4: varCodeValues(0) = "<and" intCodes(1) = 8: varCodeValues(1) = objDoc.ActiveLayer.Name intCodes(2) = 0: varCodeValues(2) = "LWPOLYLINE" intCodes(3) = -4: varCodeValues(3) = "and>" dxfCode = intCodes dxfData = varCodeValues SetName = "$Poly$" For i = 0 To objDoc.SelectionSets.Count - 1 If objDoc.SelectionSets.Item(i).Name = SetName Then objDoc.SelectionSets.Item(i).Delete Exit For End If Next i Set oSset = objDoc.SelectionSets.Add(SetName) oSset.SelectOnScreen dxfCode, dxfData DoEvents i = 2 With Application.ActiveSheet .Cells(1, 1) = "No." .Cells(1, 2) = "Layer" .Cells(1, 3) = "Nos" .Cells(1, 4) = "Lengh" .Cells(1, 5) = "Height" .Cells(1, 6) = "Multiply" .Cells(1, 7) = "Sub-total" .Cells(1, = "Handle" .Cells(1, 9) = "Type" .Cells(1, 10) = "ZoomScale" For Each oEnt In oSset Set oLWPline = oEnt .Cells(i, 1).Formula = "=MAX($A$1:A" & i - 1 & ") + 1" .Cells(i, 2) = oLWPline.Layer .Cells(i, 3) = "" .Cells(i, 4) = Round(oLWPline.Length * 10 ^ -3, 2) .Cells(i, 5) = "" .Cells(i, 6) = "" .Cells(i, 7).Formula = "=PRODUCT(RC[-4]:RC[-1])" .Cells(i, = oLWPline.Handle .Cells(i, 9) = Replace(oLWPline.ObjectName, "AcDb", "", 1, -1) .Cells(i, 10) = 0.5 i = i + 1 Next .Cells(1, 1).Select End With End With DoEvents AppActivate ExcCap, True ErrHandler: Set objDoc = Nothing Set objApp = Nothing On Error GoTo 0 End Sub Quote
