Blown Big Block Posted December 14, 2009 Share Posted December 14, 2009 At the end of a project we submit all the cad files to our clients. Prior to submitting the files we have a batch (.bat) file that loads a scrip (.scr) routine that in return runs a lisp (.lsp) routine. The lisp routine cleans up all the drawings and gets them ready to submit. It does your standard clean up on all the drawings like purging 3 times, set’s all the layers, line types and colors to bylayer, zoom extents model and paper space, runs the audit command, removes all the layer filters, saves it as AutoCAD R14, but I’m having trouble removing the Standards Checker that my company has as part of our drawing border. The problem I’m having is the command (standards). It uses a dialog box and there is no command (-standards) that will allow you to manipulate from the command line. So what happens is as the lisp routine pulls up each drawing I have to manually delete the standards then it resumes running the lisp routine. Any help would be great, I’m lost… Quote Link to comment Share on other sites More sharing options...
