Is there a way to create a helix along a radiused cyclinder? Thanks
More information is needed. Taking only the information you have supplied quite literally, yes.
I'm trying to draw a footing dowel with a 90 degree hook on one end. I tried to upload the file but It was too large even after I zipped it up.
I have created the helix along the horizontal and vertical legs of the dowel but I cannot get the helix along the 90 degree bend of the rebar. Thanks
... but I cannot get the helix along the 90 degree bend of the rebar. Thanks
That sounds like it would be a lot of work in AutoCAD. Simple Coil and Bend feature in a modern 3D program like Autodesk Inventor.
Students can download Inventor for free from http://www.autodesk.com/edcommunity
That's what I thought, Thanks for your help!
You can create a curved Helix in Autocad. I used a polar array on a single turn 360 deg helix to create this one. It's not perfect but works visually.
KC
