MiGo Posted December 16, 2009 Posted December 16, 2009 I was given a drawing that represents underground fiber communications for a very large area. I am just using the drawing as reference and had designated a linetype for these as -UC- the issue is the drawing has lines going in all sorts of different directions so some are lines that run parallel to one another have different direction text. I was wondering if there was a routine out there (that I can't find) that will scan all lines to verify that the start point of the line is closer to origin than the end line and rotate 180deg otherwise so all the text will read left to right? Quote
David Bethel Posted December 16, 2009 Posted December 16, 2009 Totally untested: [b][color=BLACK]([/color][/b]defun c:linedir [b][color=FUCHSIA]([/color][/b] / ss i en ed p10 p11 d11 d10[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ss[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\nSelect Lines Sort: "[/color][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]sslength ss[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]minusp [b][color=GREEN]([/color][/b]setq i [b][color=BLUE]([/color][/b]1- i[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq en [b][color=MAROON]([/color][/b]ssname ss i[b][color=MAROON])[/color][/b] ed [b][color=MAROON]([/color][/b]entget en[b][color=MAROON])[/color][/b] p10 [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 10 ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] d10 [b][color=MAROON]([/color][/b]distance '[b][color=GREEN]([/color][/b]0 0 0[b][color=GREEN])[/color][/b] p10[b][color=MAROON])[/color][/b] p11 [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 11 ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] d11 [b][color=MAROON]([/color][/b]distance '[b][color=GREEN]([/color][/b]0 0 0[b][color=GREEN])[/color][/b] p11[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]and [b][color=MAROON]([/color][/b]> d11 d10[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 10 p11[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 11 p10[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod ed[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]redraw[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
MiGo Posted December 16, 2009 Author Posted December 16, 2009 Sorry doesn't seem to do anything to any line I select. Quote
MiGo Posted December 16, 2009 Author Posted December 16, 2009 Let me correct myself it seems to make the lines go from right to left (toward origin) than left to right (away from origin). Quote
MiGo Posted December 16, 2009 Author Posted December 16, 2009 I have changed the greater than sign and all seems to be working appropriatly. I will let you know if it works on the whole drawing. Quote
MiGo Posted December 16, 2009 Author Posted December 16, 2009 Works great. All the lines seem to be in the appropriate direction. Thanks again. Quote
David Bethel Posted December 16, 2009 Posted December 16, 2009 Good catch on the greater than sign. Good luck There are chances that the distances will be equal. So it would be a moot point. -David Quote
