kyleh Posted August 11, 2008 Share Posted August 11, 2008 I'm using AutoCAD Mechanical 2009, and my co-worker is using AutoCAD 2009. When I run my cursor over the object "weldment", it jumps around the object. When my co-worker moves his cursor around a dimension, leader, or most objects he has the same problem. The problem does not discriminate on file size, and the computer is more than substantial to handle anything AutoCAD can throw at it. Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 11, 2008 Share Posted August 11, 2008 start with the easy stuff - have you got your snap turned on? Quote Link to comment Share on other sites More sharing options...
kyleh Posted August 11, 2008 Author Share Posted August 11, 2008 I tried turning all of them off (autosnap = 0) and it still didn't fix it. Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 11, 2008 Share Posted August 11, 2008 does that clear SNAP too or just object snaps? Try F9 Quote Link to comment Share on other sites More sharing options...
kyleh Posted August 11, 2008 Author Share Posted August 11, 2008 Snap is off. It only looks like snap when I'm moving the cursor around the "weldment" object. Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 11, 2008 Share Posted August 11, 2008 object tracking? (F11) Quote Link to comment Share on other sites More sharing options...
kyleh Posted August 12, 2008 Author Share Posted August 12, 2008 Object tracking did not fix the problem. Quote Link to comment Share on other sites More sharing options...
kyleh Posted August 18, 2008 Author Share Posted August 18, 2008 Now it jumps around when I try pass my cursor over any line or arc like the system is lagging. Does it make any difference that I'm running Vista Ultimate instead of XP? Quote Link to comment Share on other sites More sharing options...
