Hi all!
I have a road project drawings and I want to transfer some data to Excel in order to verify their correctness.
I have wrote the following code :
Option Explicit
Sub transfer()
Dim myobj As AcadObject, pct As Variant, txt As String, txt1 As String
Dim celApp As Excel.Application, wobj As Workbook, sobj As Worksheet
Dim i As Long, RETRAY As Label
Set celApp = CreateObject("Excel.Application"): celApp.Visible = True
Set wobj = celApp.Workbooks.Add: Set sobj = celApp.Worksheets(1):_ sobj.Range("A1").Activate
On Error Resume Next
With ThisDrawing
RETRAY:
ThisDrawing.Utility.GetEntity myobj, pct
If myobj.ObjectName = "AcDbSpline" Then Exit Sub
If Err 0 Or myobj.ObjectName "AcDbText" Then Err.Clear: GoTo RETRAY
myobj.Visible = False: txt = myobj.TextString: txt1 = ""
For i = 1 To Len(txt)
If Asc(Mid(txt, i, 1)) 32 And Asc(Mid(txt, i, 1)) 43 Then_ txt1 = txt1 + (Mid(txt, i, 1))
Next
If txt1 "" And Val(txt1) = 0 Then GoTo RETRAY Else _ ActiveCell.Offset(1, 0).Activate: ActiveCell.Value = Val(txt1)
GoTo RETRAY
End With
End Sub
The above code works but, because I don't know a smartly way to stop it, I must add every drawing, for example, a spline obj and to select it when I want to exit.
Could somebody help me in order to exit the above routine by pressing a key ?
Thank you for reply.
Best regards,
Marius
