bbb120 Posted December 22, 2009 Posted December 22, 2009 How to merge all layers into one ?I need to merge all layers into one ,but I don't know how .Who can help me ?Thanks in advance Quote
ReMark Posted December 22, 2009 Posted December 22, 2009 You don't want to do it through Properties? Quote
ReMark Posted December 22, 2009 Posted December 22, 2009 I think you can also use the LAYMRG command found in Express Tools. Quote
CALCAD Posted December 22, 2009 Posted December 22, 2009 Here is a simple lisp that copies all entities to layer zero and optionally deletes the other layers. No warranty. ; CLZ.LSP - Collapse all layers to layer 0, i.e., move all entities to layer 0 ; and optionally delete all empty layers. (defun c:clz (/ en el uchk) (setvar "CLAYER" "0") ; change layer of each entity to "0" (setq en (entnext)) (while en (setq el (entget en)) (setq el (subst (cons 8 "0") (assoc 8 el) el)) (entmod el) (setq en (entnext en)) ) ; delete all layers except "0" ? (initget 1 "Yes No") (setq uchk (getkword "\n Delete all empty layers? (Y)es or (N)o ")) (if (= uchk "Yes") (progn (setvar "CMDECHO" 0) (command ".purge" "LA" "All") (setvar "CMDECHO" 1) ) ) (princ) ) Quote
