count the number a given text letters e.g. 3No. H's
  • 7 months later...
  • Replies 33
  • Lee Mac
    15
  • stockers
    8
  • laijumalias
    4
  • ReMark
    3
tsel works very fine, thank you for your help
Try this:
(defun c:tsel (/ *error* unique BPT CATT CNT DOC ENT I ITM J
                    K LST OBJ OLST SPC SS TBLOBJ TSS UFLAG)
 ;; by Lee McDonnell (Lee Mac)
 (vl-load-com)
 (defun *error* (msg)
   (and uFlag (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun unique (lst / result)
   (reverse
     (while (setq itm (car lst))
       (setq lst (vl-remove itm lst) result (cons itm result)))))
 (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)) i 2)
 (cond (  (eq 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar "CLAYER"))))))
          (princ "\n<< Current Layer Locked >>"))
       (t (if (and (setq k -1 ss  (ssget '((-4 . "<OR")
                                             (0 . "TEXT,MTEXT")
                                             (-4 . "<AND")
                                               (0 . "INSERT")
                                               (66 . 1)
                                             (-4 . "AND>")
                                           (-4 . "OR>"))))
                   (setq bPt (getpoint "\nSelect Point for Table: ")))
              (setq uFlag (not (vla-StartUndoMark doc)))
              (while (setq ent (ssname ss (setq k (1+ k))))
                (setq obj (vlax-ename->vla-object ent))
                (setq lst
                  (append lst
                    (cond (  (eq "AcDbBlockReference" (vla-get-ObjectName Obj))
                             (mapcar (function vla-get-TextString)
                                     (append
                                       (vlax-safearray->list
                                         (vlax-variant-value
                                           (vla-getAttributes Obj)))
                                             (if
                                               (not
                                                 (vl-catch-all-error-p
                                                   (setq cAtt
                                                     (vl-catch-all-apply 'vlax-safearray->list
                                                       (list
                                                         (vlax-variant-value
                                                           (vla-getConstantAttributes Obj))))))) cAtt))))
                          (t (list (vla-get-TextString obj)))))))
              (foreach Str (unique lst)
                (setq cnt 0)
                (if (setq j -1 tss (ssget "_X" (list '(-4 . "<OR")
                                                       '(-4 . "<AND")
                                                         '(0 . "TEXT,MTEXT")
                                                          (cons 1 str)
                                                       '(-4 . "AND>")
                                                       '(-4 . "<AND")
                                                         '(0 . "INSERT")
                                                         '(66 . 1)
                                                       '(-4 . "AND>")
                                                     '(-4 . "OR>"))))
                  (while (setq ent (ssname tss (setq j (1+ j))))
                    (setq Obj (vlax-ename->vla-object ent))
                             (foreach Att (append
                                              (vlax-variant-value
                                            (if
                                              (not
                                                  (setq cAtt
                                                      (list
                                                        (vlax-variant-value
                               (if (eq Str (vla-get-TextString Att)) (setq cnt (1+ cnt)))))
                          (t (setq cnt (1+ cnt))))))
               (setq oLst (cons (cons str cnt) oLst)))
             (setq tblObj
               (vla-addTable spc
                 (vlax-3D-point bPt) (+ 2 (length olst)) 2 (* 1.5 (getvar "DIMTXT"))
                   (* (apply 'max
                        (mapcar 'strlen
                          (append '("String")
                            (apply 'append
                              (mapcar (function (lambda (x) (list (car x) (itoa (cdr x))))) olst)))))
                      2.0 (getvar "DIMTXT"))))
             (vla-setText tblObj 0 0 "String Counter")
               (vla-setText tblObj 1 0 "String")
                 (vla-setText tblObj 1 1 "Count")
             (foreach x (vl-sort olst (function (lambda (a b) (< (car a) (car b)))))
               (vla-setText tblObj i 0 (car x))
                 (vla-setText tblObj i 1 (itoa (cdr x)))
                   (setq i (1+ i)))
             (setq uflag (vla-EndUndoMark doc))))))
 (princ))
Is there a way to count the strings only in the selected objects in other words is it possible to give an option to count in the entire drawing or select the objects from where the count should perform.
Hi Lee, thanks for your response, Can you please provide the modified code.
He just lives to serve. :glare:
Hi Lee,
Awaiting your support on this code, thanks in advance.
Hi Lee,
I don't have much time, of which, here it is voluntary.
  • 1 month later...
Anybody with any help?
Lee, you are amazing.
Thanks for helping us always.
:thumbsup::thumbsup::thumbsup:
Did my code work for you laijumalias? Or was I wasting my time?
Thought so.
You are too kind Lee, and the kind never get the credits they deserve. You are noted down as Awesomesauce in my book though :)
