ILoveMadoka Posted December 23, 2009 Share Posted December 23, 2009 This is a followup to this thread.. http://www.cadtutor.net/forum/showthread.php?t=43123 Is there a SETVAR for the Toggle to Display Lineweight? I have something that toggles it ON from time to time and would like to just set it to be OFF when Autocad starts. In my startup preferrably. TIA!! Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 23, 2009 Share Posted December 23, 2009 Perhaps this? "The default value is set by the LWDEFAULT system variable, which has an initial value of 0.01 inches or 0.25 mm. All new layers use the default setting. The lineweight value of 0 plots at the thinnest lineweight available on the specified plotting device and is displayed at one pixel wide in model space." Quote Link to comment Share on other sites More sharing options...
wizman Posted December 23, 2009 Share Posted December 23, 2009 lwdisplay i think. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted December 23, 2009 Author Share Posted December 23, 2009 LWDisplay!! You're my hero!! On a side note how would I write a routine to go through all layers in a drawing and set the lineweight to Default for each layer? Drawings imported from Solidworks sometimes set a lineweight for different layers... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 23, 2009 Share Posted December 23, 2009 Try this: (defun c:lwd nil (vl-load-com) (vlax-for lay (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) (vla-put-lineweight lay acLnWtByLwDefault)) (princ)) Or (defun c:lwd (/ tdef) (while (setq tdef (tblnext "LAYER" (not tdef))) (entmod (subst (cons 370 -3) (assoc 370 tdef) tdef))) (princ)) Quote Link to comment Share on other sites More sharing options...
wizman Posted December 23, 2009 Share Posted December 23, 2009 LWDisplay!! You're my hero!! On a side note how would I write a routine to go through all layers in a drawing and set the lineweight to Default for each layer? Drawings imported from Solidworks sometimes set a lineweight for different layers... Merry Christmas Everyone! Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted December 23, 2009 Author Share Posted December 23, 2009 Lee... Once again... YOU ARE THE MAN!! When I grow up I want to program just like you!! Thank you and MERRY CHRISTMAS!! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 23, 2009 Share Posted December 23, 2009 Happy to help - and Merry Christmas Quote Link to comment Share on other sites More sharing options...
