SillyBilly Posted December 23, 2009 Posted December 23, 2009 Hello, all. I'm on AutoCAD 2007 and am having trouble refreshing xrefs. I'll be working on the xref file, save changes, and go back to the drawing that's referencing the xref, click refresh from the xref window, and the changes won't come through. It would also be nice to know if there is a typed command that would refresh xrefs as well. Thanks! Quote
Cad64 Posted December 23, 2009 Posted December 23, 2009 Are you sure you're working on the correct xref? Could it be you've made changes to an xref with the same name in a different location? Double check the xref file path. Quote
