draw a line using VBA with an angle and a length?
hey everyone
is there any way to draw a line, using VBA, by specifying an angle and a distance? the only way i know how to draw a line is:
Dim objEntity As AcadLine
Set objEntity = ThisDrawing.ModelSpace.AddLine(Start, End)
thanks!
will
you can only create a line by specifying a start point and an end point.
If you know the angle and the length it's easy enough to work out
To solve for it first, you can use the Utility.PolarPoint Method
thanks alot borgunit! exactly what i was looking for.
